Horsefarm Efficient Waste Disposal HELP/Thoughts
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #1
meledward23
too close to Graceland....
1025R
Okay,
Here's the scenario. I have a 25 stall horse barn. I do not have enough enough land for a manure spreader. The land I have has horses or a show arena on it, and the horses are sufficent that spreading manure makes the ground hold to much moisture and becomse a messy mud pit.
So I have to get rid of this stuff.
For the last few years the barn hand fills a three sided cart and wheels it out of the barn and dumps it into a pile. The pile is now 6' tall 70-80 diameter. It's getting to the point where the ramp to get up to the top is getting to steep. I have been plannign on a new course of action but I keep getting stumped/not happy with my idea.
It's time. I have to do something. And since I need a new driveway, new parking lot, new fencing etc. Efficient, cheap, and cost effective are all concerns. Of course the easier it is on my labor the better becuase he is hard to replace.
and Finally just a a reference we are talking about approx 37 - 60 cu Feet per day or roughly 1.5-2 Cu Yds per day min.
This stuff does compost nicely...
1) Pour a huge slab of concrete that is divided for material storage. 15'x15' type bays. Every month fill a different bay. As it composts to the appropriate level sell it.
Pluses: Easy, can make some $ off the sale of compost (not a lot).
Down Side: If I miss calculate turn around time on a crop of compost I could run out of room Quick. and that is a lot of concrete....
2) Concrete staging area. Dump Trailer (wagon). Store a weeks worth of material and move it at one time.
Pro Less: concete
Con : I have to move it every week (no one touches my tractor), and if something happens that it doesnt get moved no spill over area....
3) other methods....
Number 2 I think is my favorite.
Any suggestions? Comments, etc.... common I am brain dead on this one.... Frozen to inaction...
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #2
<font color="blue"> 15'x15' type bays. </font>
You need smaller bins for the break down to be efficient. Most large scale composting on farms use bins that are 5' to 8' wide. The length can be longer. The reason that at least one way needs to be narrow is so air can infiltrate into the compost. You don't want the height to be more than 5'. If it is taller than that the heat can get so high that it will combust. Do a search on the net for "poultry compost". You will get a lot of hits from universities that will have the moisture content, composter plans and tell how to layer it to make the process faster.
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #3
</font><font color="blue" class="small">( 1) Pour a huge slab of concrete that is divided for material storage. 15'x15' type bays. Every month fill a different bay. As it composts to the appropriate level sell it.
Down Side: If I miss calculate turn around time on a crop of compost I could run out of room Quick. and that is a lot of concrete....)</font>
Good luck! Around here, people give horse manure away and even that doesn't always work. A friend of a friend actually pays to have loads of the stuff hauled away each year. He is in a similar situation: he boards horses, and has an arena area. He does have enough land for a manure spreader which he uses aften as well, but evidently not enough land as his fields retain a lot of water and turn into muck as well.
Horse manure takes a while to compost too; the bedding mixed in doesn't break down as fast as say cow manure with only a little hay mixed in.
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #4
This calls for a good old problem swap.
1) Dig hole
2) Insert manure
3) Deal with dirt from hole instead.
/forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #5
Moonlight (Creekside) mushroom mine in PA is rumored to truck horse manure in from the large thoroughbred farms in TN and KY for their mines. You may research this and contact someone who supplies manure and have them pick it up!
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #6
Less horses.
IS it an option for you?
-Mike Z. /forums/images/graemlins/grin.gif
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #7
Hello Meled...., U've heard, the one about when U have lemons, MAKE LEMON AID! Well A long time ago I was associated w/similar operation and we didn't solve the problem but did some things that helped! We found a WORM Farmer that came & got lots of it and then we made a BIG NICE sign that said, "FREE MANURE"! with key word being FREE, seems like people like free! IS burning out or can YOU burn it! It leave about a quarter of the mess but burns/smolters for days!
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #8
Mel,
If you just want to get rid of it at no cost to you, you might want to try contacting a landscape supply/garden center type of operation that makes their own composted topsoil. The sheep farmer next door to me was doing that for his sheep - the company comes in once a year when he cleans the barn and hauls it away for free - that is, they were doing that ..... until I got back into vegetable gardening. /forums/images/graemlins/grin.gif
   / Horsefarm Efficient Waste Disposal HELP/Thoughts #9
We called around to local gardening centers, farmers, etc. to see if anyone would take ours. No one would. /forums/images/graemlins/frown.gif We ended up getting a 2 cu yard Dumpster that the local waste hauler empties every other Friday.
We only have three horses, so this might not be economically feasible for your situation.
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2005 Ford F-650 (A53422)
2005 Ford F-650...
2005 Freightliner M2 106 Box Truck (A52377)
2005 Freightliner...
2021 CATERPILLAR 279D3 SKID STEER (A52705)
2021 CATERPILLAR...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
