Horse Power vs Tiller size in Texas Gumbo clay
   / Horse Power vs Tiller size in Texas Gumbo clay #1
awill99
Bronze Member
15 acres Celeste
Mahindra 6500 4WD with Skid Steer FEL.Mahindra 3616 HST with Skidsteer, Vermeer RT200 Trencher
I currently have a 5005 DI.How much tiller can it easily handle in Texas Gumbo clay soil? If I go to a 6500 4WD?
   / Horse Power vs Tiller size in Texas Gumbo clay #2
Moisture content of North Texas clay soil is the key. Catch it at the right time and you can run any size tiller you can mount on your tractor. Catch it at the wrong time and it takes dynamite to break it up. I have 55 acres east of Van Alstyne and it is the same black Houston clay you have at Celeste. I used a 10 ft. J.D. tandem disk to prepare 20 acres for sprigging from late Winter to early Spring and moisture content was the single most important factor in working the soil.
   / Horse Power vs Tiller size in Texas Gumbo clay #3
Absolutely right. A 40" tiller behind a Kubota with only 13 PTO hp did great when the moisture content was right. It bounced and rattled on top when the ground was really hard and dry, and it even bogged down and killed the engine once or twice when it was really muddy and sticky.
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
