horse manure in gardens
   / horse manure in gardens #1
radioman
Super Member
Ontario, NY
Kubota BX24
As spring is right around the corner and I'm patiently waiting for it to warm up- I been thinking about the gardens right now. This year I plan on adding horse manure to my garden to improve the clay like soil from a nearby farm that is literally 5 mins from me. The farmer says he has BOTH aged stuff and new. I plan to add the aged stuff on top of my garden this spring after it warms up and dry out and till it all in. This fall after my potatoes are harvested, I plan to scoop the dirt a foot or so deep and move it to the short side of the garden and put all the hot stuff right there on the bottom in the fall and cover it all back up and wait till spring to repeat. Any flaws in my plan? Time is not an issue for me as I can reasonably pick up the manure and spread/till/cover whatever in a day.
I also have a side project I want to do with the garden- Tell me if I am crazy or not. I would like to pick up some pallets and cut them in half and stick it in the ground with holes pointing up in the garden ,right on the edge on the long side. I want to fillup the holes in pallet with either straight aged manure or get the good stuff from the local country max store just for the carrots to plant. My soil has too much clay in IMO, carrots is just too short so I want to grow longer carrots. Anyone want to take a stab poking holes in my crazy idea? By the way - getting the pallets in the ground will not be a problem as I got a small backhoe for my tractor. I trying to keep the "good stuff contained" in the garden just for carrots and not mixed with the clay.
   / horse manure in gardens #2
Been there done that. Horse manure is great, if you like weeds in your garden. :thumbdown:
I suggest commercial compost, or cow manure. They should not contain weed seeds.
Leaf mulch, and grindings from stump grinders, are good additions in the fall.
   / horse manure in gardens #3
We aged horse manure for quite awhile and used it in wifes garden. Had a record crop of grass and weeds.
Unless horses diet is alfalfa only (no grass or pasture) you will get weeds.
Also i did soil test of garden after using horse manure and all values were low.
We had to kill it all and redo with aged steer manure and peat moss mixture. That workod great. Veryfew weeds, good soils test results. Great garden results
   / horse manure in gardens #4
<snip> Any flaws in my plan? <snip>
Like they wrote, weeds.
Reads like very narrow raised beds. Good idea, might work. Try it, photograph it and report back.
   / horse manure in gardens #5
Pallets equal nails and they will eventually rot and release those nails to your tractor tires. Deep dig and add in some well rotted compost and you can get the earth worms and microbes to fix that soil for you.
   / horse manure in gardens #6
We have horses and compost our manure. We use it in our raised beds with peat and garden soil tilled in. We refresh the beds with new composted manure before each growing season. We have had excellent results. Not much of a problem with weeds.
   / horse manure in gardens #7
I take the sawdust/manure from the stalls to a pile that I keep building throughout the year and I turn it about once a month. I also have a tree trimming business dump a load or two of the ground up limbs in the pile as well. I usually have at least two piles going at a time and they heat up pretty good even in the winter months. After about six months the color and texture begins to change dramatically and it becomes some very good compost. For two years I spread a completed pile on the garden area several inches thick and each year the benefits were very noticeable. I can now take my hands and dig down 8 to 10 inches deep in what used to be very dense clay that struggled to drain well. Have not had a major weed problem, so far the benefits have far outweighed a few weeds. I also take bad hay and spread it thick in the rows to mulch out the weeds and at the end of the season take the now rotted hay and throw it on the manure pile.
   / horse manure in gardens #8
Horse manure has to be really well rotted to avoid a bumper crop of weeds. Either a couple of years, or like someone above does, well composted. Horses only have one stomach. A good look at a horseball can give you a pretty good idea of what the horse had for dinner the other day. Cows have 4 stomachs (technically 3); when they're done with something it's much more digested than the same feed coming out of a horse but it can still have enough seed remaining to give a few weeds.
Manure is more of a soil amendment than a great source of fertilization. Your soil will be loamier and richer, but your N-P-K won't go up that much.
I would stay away from pallets cuz of nails someday. One flat or ruined tire wipes out all the good things.
   / horse manure in gardens #9
I get the fresh manure/sawdust mix and hot compost it myself. It gets quite hot, takes about 3 months before it is 'finished'. Nary a weed to be found in the pile of 'finished' that I keep on hand.
Takes quite a bit of water but I hose the pile soaking wet, back into the pile with my tiller and spread it out into a layer about 1 foot or so thick, hose it soaking wet. Re-stack into a windrow, hose some more. I do this about 2-3 more times over 3 months and it really cooks.
   / horse manure in gardens #10
There's lots of stuff on the internet on how to improve clay soil...none of it easy, but consists mainly of adding organics, some ashes and generous amounts of sulfur and/or Calcium Sulfate (Gypsum) to add some acidity. One thing I learned from experience; it works, and even if the clay is heavy, but not too heavy to till, you can still raise a fair garden with the use of fertilizer.
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2018 LEDWELL LW48HT2-10 PB-LP (A52472)
2018 LEDWELL...
1996 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1996 HEIL TRAILER...
