hopping mower
   / hopping mower #1
hillslider
MN
Kubota L3130 JD X750 and X350
I have a Kubota L3130HST that I pull a 5' International brush cutter with. This weekend I was beating down some weeds in the horse pasture when the cutter started hopping around. Something was obviously out of balance. I shut her down and gave her the look over. No clumps of grass caught anywhere....everything tight and nothing out of place. Engaged the pto again and same hopping. /forums/images/graemlins/mad.gif I again gave it the look over and again engaged with the same hopping around. I gave up and went up to the house. Before I parked the tractor I thought I would engage the pto one more time......smooth as can be! What am I missing? I do not understand how something can be so out of balance one moment and smooth the next. Any help from all you educated tractor users? For your info I was only cutting thin foot high weeds on a smooth field.
   / hopping mower #2
I have seen cases where trash would cause one of the blades not to swing freely & cause this problem. If it happens again. Lift it up, cut everything off & feel to see if the blades are free or binding. I am talking about at the bolt where the blade mounts to the stump jumper.
   / hopping mower
This was my first thought also. I raised the mower and checked the blades.....I thought one would be stuck....but not the case. /forums/images/graemlins/confused.gif
   / hopping mower #4
Could you have a bent blade? That would cause an unbalance as well.
   / hopping mower #5
If this is a rotary mower, and the hopping is in the vertical mode, I would suspect the PTO shaft. Check it for a bound up u-joint or a bent shaft. If it is a flail type mower, there was probably trash somewhere that fell off after you quit mowing.
Good Luck
   / hopping mower
I did not think about the PTO shaft. The Mower is new and only has about 10hrs on it. But when I got home I checked the joints and sure enough the joint next toe gearbox was very tight. I greased it up and worked it and seems to have taken care of it. I plan on calling the dealer to possibly replace it....for free I hope. It is a rotory brush cutter by the way. Thanks for the input.
   / hopping mower #7
my tiller only has a 8-10" pto shaft when i had the weld off about 1/8" it bounced pretty hard i think the driver's right hand side wanted to torque up but the whole thing jumped up.
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
WOODS 5' ROTARY MOWER (A57192)
WOODS 5' ROTARY...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
