Hooking up post driver
   / Hooking up post driver #1
jrchafin
Mahinda 7520
Hey guys,
I'm hooking a post driver to my 7520. It's a worksaver HD20, and the manual says that you can't hook the return line to the tractor remotes, I guess because they don't expect adequate flow to allow the driving ram to drop without resistance. The fitting for the return line on the driver is a 3/4", and the remotes look like 1/2" (correct?). Has anybody hooked a post driver to the remotes out there? Does it work?
If I have to plumb this in without the remotes, how would I go about doing that?
Thanks!
Jon
   / Hooking up post driver #2
There are quite a few post's about these in the Hydraulics forum, a search of the term "driver" should turn them up...
The best way to plumb the return is to buy another fill cap for your tractor, and install a barbed hose fitting on it so you have a true, unrestricted "return to tank" line. Or you can just shove the return hose in the filler neck and seal with a rag or something...but that could get messy real quick.
Woods 3 pt RM 550 Finishing Mower (A50515)
Woods 3 pt RM 550...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
