Hooking chain to the bottom bar- how do you?
   / Hooking chain to the bottom bar- how do you? #1
Slacker
Durham, NC
Farmtrac 360 TLB
The bar that resides on the bottom of the rear axle (swinging draw bar?) has holes in it. It can extend out for additional turning radius.
I know that most farm trailers have the female end for connecting to the bar. Lawn tractors have a similiar connecter. I'd like to hook a chain to this bar for pulling stuck trucks, rocks and the like. How does everyone connect a chain to the lower/swinging drawbar? The holes are too small for a chain to go though.
   / Hooking chain to the bottom bar- how do you? #2
Clevis and hitch pin.
   / Hooking chain to the bottom bar- how do you? #3
Use a clevis through the draw bar hole and hook a chain to that.
   / Hooking chain to the bottom bar- how do you? #4
I have a trailer hitch ball on mine for pulling a trailer. It also works great for wrapping a chain around. Use a grab hook and make a loop on the end of the chain.
   / Hooking chain to the bottom bar- how do you? #5
As stated, a clevis is the answer. Any farm supply store will have them.
I keep one mounted on my drawbar, since I don't pull any implements from there, and one mounted on my grill guard, so when I load/haul the Bota, chains easily pass through the clevis, with one twist to keep them from sliding, for tie downs.
What I usually do to unload at a job site is slack the chains, then pull the pin, leaving the clevis (with the chain still through it and attached to the trailer) on the trailer.
When I load again, all I have to do pick up the clevis, drop the pin in the hole, and cinch the binders.
Hope this helps.
ron
   / Hooking chain to the bottom bar- how do you? #6
I have a big hook similar to the clevis JohnK posted. You can find them at most farm stores
   / Hooking chain to the bottom bar- how do you? #7
I don't keep my drawbar in place, but I also have a clevis that I use with it when needed. However, the 'box' on the bottom of my tractor into which the drawbar slides has an edge that holds a 3/8" chain hook very nicely so I don't really need the drawbar or clevis if I have a chain with a hook on it.
   / Hooking chain to the bottom bar- how do you? #8
Big ole' honkin' clevis for me too, the pin almost fills the hole.
   / Hooking chain to the bottom bar- how do you? #10
I have one of each, depending on what I want to do and how much hooking and unhooking will be going on.
I wouldn't make a habit of pulling heavy loads with the chain hooked to the "box" the drawbar fits into. The chain hook puts a lot of load on a small area and you might bend some steel you'd rather have flat. When the bar is in there the load is spread out over a larger area through the bolts or pins.
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2006 Xpress 27ft. Gooseneck T/A Horse Trailer (A48082)
2006 Xpress 27ft...
2014 Ford F-350 Altec AT200A Insulated Bucket Truck (A48081)
2014 Ford F-350...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
LOT LOCATIONS (A51222)
2018 Ford Explorer AWD SUV (A48082)
2018 Ford Explorer...
