hood wont stay up.. part help please
   / hood wont stay up.. part help please #1
platinumaa
hello again all.. i have a r4041.. and the hood doesnt stay up.. actually it never did.. or is it not suppose to? if it is suppose to does anyone know where i can get the new "shock" (i assume thats what its called) that holds it open (see 1st pic)
also, i had the extra hydraulics added so i can use grapples.. is there something i can buy to cover it when the hoses arent attached? or do people just cover with a rag and a rubber band? (see 2nd picture)
thanks!
   / hood wont stay up.. part help please #2
Hi. I have the r4041 and yes the hood stays open on mine. I would bet you could get something that would work from an auto parts store. Seems like it is identical to the parts from a truck camper shell that hold the door/gate open. As far as the other part try a TSC.
   / hood wont stay up.. part help please #3
I want to say I've seen plugs for those in the same aisle at TSC... If not, you could always buy another male & female coupler to pop on while not in use.... fill the back of it with silicone or "great-stuff" foam so it stays clean.
   / hood wont stay up.. part help please #4
Yes, that does look a lot like a prop for a camper shell / rear hatch for station wagons & blazers, so auto parts stores likely would have it. Is there a ball at the bottom that pops off fairly easily?
The Ford 1715 has a prop that looks like this.
Ford New Holland 1715 Tractor Hood Prop | eBay
It is mounted to the right SIDE of the hood. A pin slides up the groove, then there is a little notch that it drops into. Just lift it out of the notch and the hood closes.
Unfortunately, since the bar does slide, there likely wouldn't be room for a center mount on your tractor, so everything would need to be changed for a side mount.
i assume TSC is "tractor supply"?
all great advice.. i appreciate it fellas.. thanks!
   / hood wont stay up.. part help please #6
My hood would not stay open when I bought mine. My dealer got a new lift support for my tractor.
   / hood wont stay up.. part help please #8
Why wouldn't your dealer just give you a new hood shock under warranty??
New Holland 1431 Discbine (A50515)
New Holland 1431...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
EZGO (A50324)
EZGO (A50324)
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
