Hood won’t open on my branson 3520. Hood release lever has no effect.
   / Hood won’t open on my branson 3520. Hood release lever has no effect. #1
Johnhmorton
Branson 3520
Hood won’t open on my Brandon 3520. Hood release lever has no effect. Any thoughts?
   / Hood won’t open on my branson 3520. Hood release lever has no effect. #2
John more than likely the hood release latch has come undone from the linkage and spring, what year model is your 3520? 2014-2016, or 2017-2019 if the older version you should be able to have enough room to take a long flat head screw driver and slide it just under the front lip of where the hood meets the frame and using that you should be able to push the latch up opening the hood, if you have the newer version you will have to remove the retainer band from in between the hood and firewall should only be one nut holding it in place once that has been removed you can gain access to the hood support stutrs backsides and you can remove the retaining bolt that mounts those once you have those undone you should be able to tilt the hood forward enough to get the hood latch to release.
   / Hood won’t open on my branson 3520. Hood release lever has no effect. #3
The hood release on my TYM T233, involves: Pulling the handle and them smacking just above the latch on the hood. And then lifting the hood without releasing the handle…. Tried adjusting, to no effect. Guess it good in a way. it won’t accidentally pop open.
   / Hood won’t open on my branson 3520. Hood release lever has no effect. #4
Mine had that problem once. I had to push down on the hood hard before pulling the handle. I put some shims under the latch catch before closing it again.
2014 John Deere 700K LGP Dozer (RIDE AND DRIVE) (A50774)
2014 John Deere...
JOHN DEERE 2840 TRACTOR (A51243)
JOHN DEERE 2840...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
