Honda weed-eater GX35 problem
/ Honda weed-eater GX35 problem #1
IanM
Kenwood California
Kubota L2550GST
My three year old Honda GX35 has a fuel problem. With a full tank of gas it runs perfectly but as soon as the tank is down to about 75% full, it starts to lose power, stalls, and will even quit. If I hold it upside down it will run fine for a few minutes. As far as I can tell the fuel filter rests in the bottom of the tank like it should. I've replaced the air filter, the fuel filter, cleaned the spark arrestor (even removed it), cleaned out the fuel tank, soaked the carb inside and out with carb cleaner and it still won't run right. I'm reluctant to disassemble the carb but maybe that's next. Any ideas?
Thanks for your help.
/ Honda weed-eater GX35 problem #2
Check for a crack or hole in the fuel line. The little filter may rest on the bottom ,but if there is a crack in the fuel line it starts sucking air and looses power. The gas we buy now is bad for these fuel lines . They are usually easy to replace and most parts stores sell them in the #of inches you need.
Good suggestion. I check it out tomorrow.
Thank you! A new fuel line did the trick.
EZ loader trailer (A56857)
EZ loader trailer...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
