nedbrod
Good afternoon! I recently acquired a Honda 6522 tractor (vintage 1995/96) that runs very well and is in reasonably good condition. i do have a question regarding the hydraulic system for the front bucket. In order for it to operate I have to raise the rpms way up to raise or curl the bucket. I believe it should operate with the engine rpms at least a little above idle. All speeds work fine as well as the four wheel drive system. Also see that the rear pto seems to operate perfectly. I've changed the transmission fluid and filter with no improvement. Is it possible that there is an adjustment to the valve assembly that can compensate for this? Any help would be greatly appreciated. Thanks in advance.
