Honda mower engine setting guide?
   / Honda mower engine setting guide? #1
chelydra
Ditch Witch
My HRM 215 K4SDA ran great for years. Then somehow a stick jammed in under the carb, bending the stiff wire choke linkage. Since I reassembled it, it's been almost impossible to start and has little power.
I think I need to re-adjust all the mixture/idle screws, cable tension, etc. Dealer is gone, and there isn't another close by. Is there an affordable repair manual that addresses this level of detail, or do repair experts just know all this from experience?
I think this mower has many years left in it, and am willing to do some work to bring it back into shape.
Thanks in advance for any advice. I may just play with it for a while (hard to damage a Honda engine), and then find a local small-engine fixit person if need be.
-Chelydra
   / Honda mower engine setting guide? #2
Its been my experience that the manuals are good for torque specs and other engine specs but most of the knowledge to repair something comes from just doing it, and learning from your mistakes. The dealer manuals give you disassembly and reassembly and troubleshooting to the basic level but not enough information that a non mechanically minded person could fix anything by just reading the manual.
... I may just play with it for a while (hard to damage a Honda engine), and then find a local small-engine fixit person if need be.
-Chelydra
Well, took it apart and put it back together without a guide, just guessing on settings. Started on first pull and seems to run at least as well as when new - maybe better. What an amazingly tolerant engine!
Always like happy endings.
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
