Honda ht 3813 lawn tractor deck parts
   / Honda ht 3813 lawn tractor deck parts #1
scottdanny22
soap lake washington
Honda ht3813
I have a Honda ht 3813 and I replaced the bearings in the housing that has the spindles that the mower blades attach to the problem is the threads inside both pendles are stripped very bad I need help in finding replacement spindles or is there another brand that will work thanks Scott
   / Honda ht 3813 lawn tractor deck parts #2
Can you substitute a bolt w my lock nut? Maybe drill it out for larger size first. You probably thought of and rejected that already...
Jim
Jim
i tried that but there wasnt alot of room in the shaft and Iam afraid of them coming loose and a blade flying off also not sure what grade bolt to use anew set ofthose spindles would be the ticket or if someone knows of another brand that would fit thank you for your reply
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2005 International 8600 Hydro Vac Truck (A53117)
2005 International...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
