Tiller Homier Tiller
   / Homier Tiller #1
chucko
Veteran Member
Polk Co , Fl
bx1800
anyone have one? are they any good or just juck? Cost seems to be about 1/2 of the other small ones
edit to add a pic
   / Homier Tiller #2
chucko,
do a search, i think others have commented. I saw a Homier tiller long distance - they had one at a local show, but it was in a marshalling area that was roped off. Even at a distance I could see why it was 1/2 of what you would expect to pay for a tiller. I like to think I am good to my equipment, and I would not want one of these, after seeing a tiller in action and the abuse they take. Just my thoughts, I'm sure others will weigh in.
P.S. I have alot of clay - rocks where there isn't clay with some occasional loam thrown in to fool you, so this is tough tilling country - your situation may be different.
   / Homier Tiller #3
It's a rice field style tiller.
   / Homier Tiller
Ok so I am in FLa and its mostly sand... comments?
   / Homier Tiller #5
Mark, how does a rice field tiller differ from a "normal" tiller?
/forums/images/graemlins/smile.gif
   / Homier Tiller #6
chucko what was the old saying, you get what you pay for??? /forums/images/graemlins/grin.gif
   / Homier Tiller
I known....I just saw it and had to ask. Its not like sand is too hard to till you know
   / Homier Tiller #8
If you have sand then it probalby will work out OK, it looks similar to the unit I have with my jinma tractor, (though mine uses the center gearbox to transfer the rotational forces and that one looks to be a chain drive unit with the chain on the outside edge. the unit I have workts prety dang good. it has taken some nasty abouse and has yet to break a tine even! (knock on wood) I've plowed up soem pretty LARGE rocks with it too, (one was probalby 100 lbs, but was caught by the center harrow point rhater than a tine.) I've hit stuff that was not moveable with tines and it made the hole thing jump out of the ground prety fast. I till in lowest 2 gears in low range, I can literly get off the tractor and walk around it with out fear of it getting away! hahaha. WOT is only about 2 MPH in those gears and lowest is probalby a lot less.
Mark M /forums/images/graemlins/smile.gif
   / Homier Tiller #9
chucko I have a BX1800 to.I bought a 42 tiller from CCI.So far I no complaints.It does a good job.Once you use one I don't think you will go back to the other kind.They told me it would be there on a certain day and it was and if you have any questions they are very helpful.
   / Homier Tiller #10
I would look for a good used piece of equipment.You should be able to find one of those for what you would pay for a new "cheaper" one and it would probally outlast the cheaper one too. Just my 2 cents worth.
Donny
2121 (A51244)
2121 (A51244)
Year: 2010 (miles exempt on title) Make: Chevrolet Model: Malibu Vehicle Type: Passenger Car (A51694)
Year: 2010 (miles...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
