Quick Hitches Homier 3pt. Cat.1 Quick Hitch
   / Homier 3pt. Cat.1 Quick Hitch #1
jjcc246
Buffalo, New York
2004 TC30
I posted a while ago that I bought a Homier 3PT. Quick Hitch. Just an update. After waiting for some missing parts, I finally received them. The adapter bushings were wrong so I went to TSC. The actual adapters are $23.00 a set and are put on the implements pins with spring pin (might be the wrong name) but if you use that then if someone else without a Quick Hitch wants to use the implement, you have to drive the pin out to go back to regular 3PT. I bought Cat.1 to Cat.2 adapters ($1.56) and Clevis pins ($.20) and it works perfectly. Just back up to the implement, line it up and lift, it's done. to drop the implement just lift the levers (from the drivers seat) and lower the 3 Pt. and it's off. What a sweet setup. I'm sure that Homier isn't built as good as Speeco or John Deer but it works. For $99.00 and $6.00 at TSC., I'm a happy tarctor owner.
   / Homier 3pt. Cat.1 Quick Hitch #2
Hey great. If it works for you, its just as good as Deere or SpeeCo, IMO. /forums/images/graemlins/wink.gif
   / Homier 3pt. Cat.1 Quick Hitch #3
I just picked one up today for 99.99. Hope mine will work as good for me as yours seems to work for you. Can't wait to get home to try it out.
Rich
   / Homier 3pt. Cat.1 Quick Hitch #4
I got mine off ebay, because of shipping costs (Homier website and Northern shipping was more than cost of item). UPS delivered it yesterday.
I will to modify it with quik tach plate so I can mount my boom pole on FEL.
David
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
1999 John Deere 7810 4wd Tractor (A52128)
1999 John Deere...
TEST YOUR BID BUTTON! (A51244)
TEST YOUR BID...
2015 Dodge Charger (A50324)
2015 Dodge Charger...
