ocaj11
- Joined
- Jun 17, 2004
- Messages
- 190
- Location
- Northeast Texas
- Tractor
- John Deere 5325 4wd, Kubota B7500 HST
I have been looking at root grapples for my DK55 FEL. So far, the cheapest I've found that looked heavy duty was around $1,500 on ebay. Since I really don't want to spend $1500, I have been thinking of building something myself. My one simple need is to pick up and move downed logs and brush to several central brush piles on 56 acres.
My theory is that I don't necessarily need hydraulic cylinders to clamp the grapple arms. I would like to build something that uses the normal curl of the bucket to open/close jaws which would hold the brush long enough to deposit onto the brush piles.
Hopefully this make sense. Open the jaws so I can use the FEL to rake up logs/brush into small piles. Drive into the small brush piles and use the curl to close the jaws and grab the brush. Open the jaws to drop the brush.
Does anyone have a picture of something homemade that would work?? Also, are there any companies that make somoething like this?? This should be cheaper than using hydraulics and would seem to be easier to operate using the standard 4 way loader controls. Thanks for your help....
If I can't figure this one out, I'll purchase a grapple, but would rather find something less complicated..... /forums/images/graemlins/shocked.gif
