I posted this to be funny of course but I put it in the Attachments Forum for a reason.
First the story. I'm starting my tractor shed and corral. The shed requires 12 three foot deep pole holes. The fence will require about 30 two foot deep holes. At this point I'm not thinking about the fence. And up until this weekend I had no plans to buy a PTO post hole digger. I don't want one and I'll probably never use it again after this.
Well, this weekend I figured that I'm still young enough and tough enough to dig post holes by hand. Well, twelve post holes later, even with the help of my son (pictured above) I'm pretty much done digging them by hand.
Let me tell you why: my dirt. There are three layers. The first is about 2-4 inches of topsoil. Below that, clay. Not like red Georgia clay. It is yellowish or grayish and in terms of consistency, imagine pottery clay. They call it bull tallow. When you set the PHD in the hole, the clay is so dense you can't close it. And then when you try to pull it back out, you have to yank it out of the clay. So you have to take small bites and when you pull it back out you can't get the stuff out of the PHD without banging it on something or scraping it out! And if you set it down in the waste pile more clay sticks to it. It is maddening. The clay goes down around 18". Below that is this hard crumbly stuff with lots of mica in it. The PHD won't touch it. So you have to chip away at it with a long pointed pry bar. I give out after 6" of that stuff. So none of my holes is more than 2 1/2 feet. It will just have to do.
Once I get the shed up I've got to put the fence in. And I'm not digging 30 more holes by hand. Either I need to rent a gas powered one or I need to buy one for my tractor. I can't find a PTO one for rent. So is it worth buying one for 30 holes? After that I think it would just sit and rust. Are there other uses for a PTO PHD? Do those of you who have them use them often? For what?
