Homemade Front or Rear Ballast Box
   / Homemade Front or Rear Ballast Box #1
GPintheMitten
Elite Member
Flushing, Michigan
Kubota B2620 with BH65 backhoe, Ford 2N
I needed some weight on the front of my Kubota B6200 to counter the rear snow blower. But I'm going to build a fel one of these days so I may want rear ballast too.
So I built a frame that I can hang on the front and put homemade concrete weights in. I put lower lift pins on it for when I want to put it on the rear. Also included a 2 inch receiver. I haven't put the top link on yet, but have the steel to do it later.
The steel box weighs 80 lbs empty and each concrete cube weighs 40 pounds. I also have an old battery that I can strap on top that weighs another 40 pounds and if that isn't enough, I can put my portable winch on a 2 inch insert bar which would add about another 80 pounds.
So I can configure it as 240 lbs or 280 or 360 lbs. When I made the forms, I put in small blocks inside the forms to make space for the receiver and the lower lift pins. Here's a few pics.
More pics in next post.
   / Homemade Front or Rear Ballast Box #4
My B7200 has manual steering.
Does yours as well?
I was curious how it steers with the load.
   / Homemade Front or Rear Ballast Box #5
Two for the price of one..nice job. :)
No power steering??but you can +- the weight factor for easier steering.
   / Homemade Front or Rear Ballast Box #6
WOW!!!!!
NICE WORK!
Thanks for the positive feedback guys.
I don't have power steering. I had it in low and 4 wd to move it around and load it on my trailer. It was noticeably harder to steer but there was no snow either. So I think it will work fine. As mentioned I might take a block or two out. We haven't got any snow to blow since I finished this.
It was a fun and rewarding project, although a bit cold in the garage doing this, especially for painting. But the kerosene heater helped.
   / Homemade Front or Rear Ballast Box #9
Just a couple of questions.
1. Are you sure those blocks only weigh 40lbs??? A concrete cinder block weighs that and it looks like you have way more volume of concrete. What are the dimensions of each block??
2. Not really a question but more of an observation/suggestion.
In its current configuration it won't work on the 3PH. You need some sort of upright to tie into the toplink, otherwise the back/reciever end will either be pointing down or dragging the ground.
But nice work though. Looks Awesome
LD1,
You're right the 3rd (top) link is missing. I'm going to add that later. I needed to finish up and take it up north to our cabin this past weekend and didn't have time to fab the top link. I will need it when I put it on the rear for the fel counterweight.
Regarding the weights, yes, I used 2 bags of 80 pound redi-mix. I also calculated the weight before I built the forms. Here's a handy formula:
An 80 pound bag of redi-mix has .66 cubic feet of volume. By the way, that is the same as a 5 gallon bucket, but I digress. 0.66 cubic feet is 1140 cubic inches. Each form was 11.5" tall by 9.26" wide x 5.5" deep which is 585 cubic inches and weighs in at 41 pounds, but the blocks I put in to create voids for the receiver and the bottom links offset the extra 4 pounds, plus when I filled the forms, the concrete only filled to 11" tall. So they are very very close to 40 pounds each.
I think blocks with voids are 16" x 8" x 8".
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
UNUSED FUTURE VIBRATORY ROLLER (A51244)
UNUSED FUTURE...
2008 FORD F-750 (A50854)
2008 FORD F-750...
2017 JCB 3TS-8T TELEKSKID SKID STEER (A51242)
2017 JCB 3TS-8T...
