lightninboy
I was blessed with some spilled field corn. I was wanting to make homemade Corn Nuts but never got around to it. So I figured now is the time to try.
I experimented this way and that way and settled on making parched corn for breakfast cereal with a hot air popcorn popper.
I don't use dry corn and I don't use steeped corn: I use washed corn. I need to make sure the corn is clean anyway, especially if I shoveled up some dirt with it. A little moisture on the outside of the corn helps keep it from getting burnt looking. I want the corn to come out swelled and golden with minimal darkness on the kernels. I put less than the recommended amount of corn into the popper. I stop the popping and dump the popper as soon as the vigorous popping stops. Sometimes I don't even get any vigorous popping. I examine the finished kernels and every kernel should have a crack in it. A hot air popcorn popper can shut down from overheating, so I don't run it long at a time.
