Homemade Cab?
   / Homemade Cab? #1
TMcD_in_MI
NW Lower Michigan
JD 4310
Has anyone ever built his own tractor cab? It's getting mighty cold out there in the tractor seat, but I don't really have a thousand dollars or more to buy a tractor cab. I'm thinking about welding up a frame out of small square tubing and having a local canvas shop make a cover for it, or maybe use 1/4 " plywood. If I use plywood, I don't know about the windows. Any ideas? Plexiglass? It won't be fancy, but if it keeps the wind off, I'll be happy.
Tom
   / Homemade Cab? #2
I have the same problem with my B2710. What I have been thinking of is a heat houser. I know that Tractor Supply sold them a couple of years ago. I don't know if they are still available now. If I remember correctly they were about $300.
   / Homemade Cab? #3
I went to a local auto glass replacement dealership and got a roll of 20 ga plastic. It's what's used for rear windows in convertables and boat cabins. It was 54" wide and I got 9 ' for 25 dollars. should be enough for 4 windows, I hope. I'll use some 1/2 in rod I got from work for frames and sandwich the plastic between flat stock, either plywood or 1/8 steel. It was going to be done first of dec. but something came up and I haven't got back to it. Oh yeah, It attaches to a sunshade I made last summer for a roof. Right now I'am trudging through about 18" of snow to get to the barn so I'd better get back to it soon. Heat will have to come from a heat houser type cover from the motor back to the front of the cab.
   / Homemade Cab? #4
I have done it for a JD 4400. Do a shearch for
Cab in progress
#222423 - 01/04/03 08:33 PM in this form
I do not know how to paste it here. Any other questions just holler.
   / Homemade Cab? #5
I am working on a homemade canopy this winter. I was hoping to put some sides on it later for a semi-cab. I was thinking of plexiglas, and then putting windows in the front and rear like you see put into conversion vans. They usually tilt out for ventilation, and are safety glass, so I could run wipers on them without scratching. Hope you beat me to it and post some pictures!
   / Homemade Cab?
Thanks DDT and Brent. I found the thread on DDT's excellent cab. That's what I would like, but probably not what I will end up with. /forums/images/graemlins/smile.gif It gives me something to shoot for, though, and I really enjoyed looking at the outstanding work.
Tom
   / Homemade Cab?
</font><font color="blue" class="small">( I am working on a homemade canopy this winter. I was hoping to put some sides on it later for a semi-cab. I was thinking of plexiglas, and then putting windows in the front and rear like you see put into conversion vans. They usually tilt out for ventilation, and are safety glass, so I could run wipers on them without scratching. )</font>
Sounds like a good idea, Marty. I will put those on my list.
Tom
   / Homemade Cab?
</font><font color="blue" class="small">( I went to a local auto glass replacement dealership and got a roll of 20 ga plastic. It's what's used for rear windows in convertables and boat cabins. )</font>
I was wondering where to get that stuff. Thanks for the tip.
Tom
   / Homemade Cab?
</font><font color="blue" class="small">( I have the same problem with my B2710. What I have been thinking of is a heat houser. I know that Tractor Supply sold them a couple of years ago. I don't know if they are still available now. If I remember correctly they were about $300. )</font>
Bob, is a heat houser just a heater, or does it include some kind of enclosure for the driver?
Tom
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
