andyfletcher
Bronze Member
- Joined
- Mar 16, 2004
- Messages
- 65
I'm thinking of building a homemade 3PH backoe out of 4" X4X 1/4in box steel. Would that be thick enough? My gusset plates would be 3/8in plate, drilled for 1in cylinder pins.
I also notice that most of your main booms are simply angled downward, and at the point of the bend you guys don't bother with articulating it here and instead simply weld on steel plates to attach the two cylinders, one for the boom pointing back, and the other for the forward arm.
Wouldn't it be better to have a working split boom, then you can work closer to the tractor and in tighter spaces?
Also I was thinking of simply using threaded 1 1/2in square thread rod for the outrigger pads, saving me a spool.
On gang spools, what order is best side by side. Bucket next to forward arm, then boom, then swing cylinder?
My tractor is 9GPM, and my 3PH is powered by an internal 3in piston(IH424), so I know right away a 3in cylinder would be too slow for a backhoe with this pump. Should I stay with cylinders with smaller pistons thereby giving me a faster operation? Say, 2in cylinders and less?
Rodded cylinders are cheaper, are they OK for this job?
The boom cylinder would need to carry total weight plus earthload, plus pressure applied by the forward cylinders, should I use a larger cylinder for it?
Thanks for the help.
Fletch
Fletch
