Homelite 14" from Home Depot
   / Homelite 14" from Home Depot #1
JoeinTX
Platinum Member
Arlington, TX
'51 ford 8N
I needed a little saw for the town place and have spent some time looking over all of the makes and models and re-mans, etc. Most of my experience is with Husqvarnas and they are good saws. We've got a couple of them for the ranch but I got tired of hauling them around and never having the right one with me when I needed it so I decided I was going to get another one for light duty.
I checked out Craftsman, Poulan, and Homelite. The Sears saws are hard to argue against considering the backing, but, they are essentially Poulans in a different color. The Poulans are easy to get and pretty cheap but, ****, they are ugly. So, I didn't go with either of them.
After reading a variety of very mixed reviews I picked up a Homelite "14 saw at Home Depot. I bought a Homelite weed-eater 6-7 years ago from them and you can't kill the darned thing. It just runs and works and keeps me from replacing it. And, I do work the **** out of it. Thus, when checking out the Homelite saws of late I had that in mind.
Got it out and fired it up......hard cranking at first but then it settled in. Filled everything and went to work. I went about trimming some trees and cutting some limbs for firewood and the saw worked liked heck. Didn't die or stutter or whimper. It has the tool-less tensioning system which is good in theory and worked but is not ideal for the long-term considering the amount of plastic used to create it. It will break, only a matter of time, so I'm already ordering the part anticipating it's failure.
Good little saw and motor, stays on bar, will do the light residential stuff. Don't push it too far, though. If you have any reasonable chainsaw experience you can handle it.
   / Homelite 14" from Home Depot #2
FWIW...
fore-ground
In April of 1986...here on the central West coast of FL we had what is known as a "No Name Storm"...it developed out of a tropical wave/disturbance in the Gulf of Mexico and very quickly generated into a tropical storm just about the time it (the tropical depression) made landfall...
...This storm caused more damage than many named storms that have hit the same area...
At any rate there was considerable damage and trees down everywhere...I scrambled to what was then called 'Scotty's',similar to HD etc....
I bought the only saw they had left (14" Homelite XL) and because they had no power they had to have cash or a check...
to get to the point...that saw is still running and cutting very well for a saw that has been worked to no end in all those years...
I've had to replace the cord a couple of times and the sprocket once....been through many bars and untold chains...
treat it well and don't guess on the oil mix...use the OEM's specs to a T...
   / Homelite 14" from Home Depot #3
The Homelite name has been passed around for some time, and isn't the saw it used to be 35 years ago.
Now a Chinese product. But if it runs, fine. :)
Oh, it's certainly Chinese made these days like most residential and retail produced items. I didn't go into the purchase expecting any different. This has no bearing on my rating it's performance and value. I don't see Americans, Japanese or Brazilians putting it together any better. Couldn't buy an "American" saw anywhere near price or convenience for a "workin' man" money considered.
So, drop the "Chinese" grap.....
   / Homelite 14" from Home Depot #5
Yep, they're cheap. Excuse me, low cost. In the short term. but you'll get at least six homelite's worth out of one Stihl. And your local Stihl dealer will fix it when its broke. No one will fix a homelite - they're trash when they stop.
Mf.
   / Homelite 14" from Home Depot #6
Had great service out of a Craftsman saw from 1973 that was made in Japan.
Sears was the first place I went a couple of years ago when I needed another one.. ended up taking it back and buying an ECHO that I am very happy with.
Took the Sears saw back because it would leak oil just sitting and I was not going to deal with that since I keep the saw in my Truck... happy to say the Stihl, Echo and 1973 Craftsman never leaked...
How's the Homelite for seeping oil when in storage?
   / Homelite 14" from Home Depot #7
Echo makes the best 2-cycle power units these days. You see Husq and Stihl running adds. Never see an Echo add. Their money goes into development.
Echo cs440 chainsaw. Just installed a new chain. I had forgotten how fast this saw cuts.
Echo PPT-265 power pruner. A mans tool for sure.
Never leave gas in a 2-cycle for more than a few weeks if you want it to perform correctly.
Check out the Echo 610 evl. 2 cylinder saw, no longer available. Now a collectors item. Referred to as the "Evil twin". http://www.youtube.com/watch?v=gSgTFR3x6-g
A weed trimmer is called a weed trimmer. A "Weed eater" is a piece of junk.
I feel better now.
   / Homelite 14" from Home Depot #8
A compelling argument supported by sound scientific data. Sounds like I should trade my crappy saws for an Echo. :confused2:
   / Homelite 14" from Home Depot #9
.............. Echo cs440 chainsaw. Just installed a new chain. I had forgotten how fast this saw cuts.............
Any saw that has a running/functioning motor will cut well if the chain is properly sharpened. :) Just a combination of the two working together. (operator will have some affect as well ;) )
   / Homelite 14" from Home Depot #10
Stihl chainsaws are the best buy for the money. With dealer service and parts Stihl is the only chain saw to own for the home owner. The model MS180 with the easy start feature makes a nice addition to anyones tool room.
Check this video out about the MS 180
YouTube - Stihl MS 180 C-BE Chainsaw-DIY
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
Toro Workman Utility Cart (A51694)
Toro Workman...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
