Home shop crack detection?
   / Home shop crack detection? #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
Have a piece of cast iron that was previously welded and the weld didn't hold. I'll be grinding it out and replacing the welds. I can see several cracks which are parallel to the original weld that will now need to be repaired as well. Once I start grinding out the welds I'll probably loose sight of these secondary cracks. I've heard of people mixing chalk with acetone, but I don't want to risk contaminating the weld. Is there something else that can be used in the home shop? Please don't say manga flux because that's prograde stuff that requires special equipment.
   / Home shop crack detection? #2
Would naval jelly be an option to accentuate the crack?
   / Home shop crack detection? #3
One old way was gasoline. It evaporates quickly from the good surface, then seeps from the crack for a while.
Bruce
   / Home shop crack detection? #5
Drill the ends? Do you have any plumbers in the family?
Brett
   / Home shop crack detection? #6
How about dye penetrant? That should work; it should show any cracks. As for contamination, you're going to want to grind out any cracks for welding/brazing anyway. Be sure to stop drill ends of cracks if possible.
   / Home shop crack detection? #7
As suggested, Dye Penetrant in a spray bottle might be one way.
You may have to do more grinding than anticipated.
I did a little research last night and was able to find this stuff: Products | Detroit | Weld-Aid You need all three products and they're roughly $10 a can. I placed an order with Grainger and it'll be available on Tuesday. I'll report the results when available.
   / Home shop crack detection? #9
What is the part? If it's critical to safety, and it has parallel cracks, it should be professionally tested! I usually tig-braze cast iron, unless I can heat the whole piece, then I weld it with nickel. It's my least favorite material to weld (I'd rather weld titanium!)
Engine block
2009 VOLVO VNM DAY CAB (A52576)
2009 VOLVO VNM DAY...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
Pop up camper (A51694)
