Home Built Box Blade
   / Home Built Box Blade #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
I'm working on building my own box blade. The project grew from me needing a ripper right now. The ripper project is now done so I'd like to finish the box blade. I'm having trouble finding the wear edge. Does anybody have a source or a material specification?
   / Home Built Box Blade #3
Cord,
Not sure where you live but if you live in snow country the folks that do the snow plowing change out blades on occasion and the blades they use should work for you. I have a couple of the cast blades and they are okay for some things but can be brittle and the one I have on my FEL did crack and was welded but the weld did not hold up. I think it was from the 50's. I am having the old blade cut off and a new blade welded on, the guy that is doing it is using 1/2 inch steel with an edge ground on it. This should last me as long as I live and should work for you.
Farwell
   / Home Built Box Blade #4
Cord,
Farwell
   / Home Built Box Blade #5
Over here in Holland, there are some parts retail store that sell universal wear parts. also, in a 30 km radius from my place there are about 4 welding shops of dirt scoops and land rollers that have them in stock. Those are the places to start your search.
If you want to make your own, Hardox 400 is premium. Other types are manganese or borium steel.
   / Home Built Box Blade #6
   / Home Built Box Blade #7
Cord, check with your county road maintance dept. as they change them out from time to time.
   / Home Built Box Blade #8
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
