Newhollandharley
OK I'm back for more punishment. Last time out you gents helped me break a
TC35D in half to repair a severely rusted clutch. It went really well and has worked beautifully ever since. Now I've got a wild hair thinking I'm going to
fabricate a home-built rototiller for this little 35 HP boomer. After I looked at the cost of buying one factory built I'm dead set on building one. I have a lot more time than money. I've got all the tools a man could use, it's a matter of steel for the most part and I can handle all that. Questions I have are like: Whats the ratio of the gear box on most rototillers? Could using a truck rear end come close? If not couldn't I fine tune the RPM's with the ratio created between the output shafts at each end of the truck rear end (where the wheels would go normally) and the gear on the tine bar that does the digging? I think a heavy duty chain drive would be strong enough. I have forgotten, what's the output speed (RPM) of the PTO shaft on a TC35D New Holland ? Then I'll have to look up the ratio of some commonly available junk yard rear ends then finally find out what is the average speed (RPM) of the tine bars of most rototillers ? Were talking six foot wide variety. Anybody out there wise to this stuff, any body tried this at all. When I look at the tillers on the market today they look just like a truck rear end, where the tires would go they have chains or gears that run a tine bar slung below the rear end .... that's it. I know that the RPM of the engine is important to the HP output and the RPM of the tine bar is important too. So I'm just looking for some tips. Lemeknow
