Home brew tongue weight scale
   / Home brew tongue weight scale #1
nikdfish
Veteran Member
Person Co. NC
John Deere 3038E & 1025R FILB
I have wanted an easier way to judge tongue weight (i.e. no bathroom scale & lever), but didn't want to pay for a $140+ scale. I finally put together a "budget" version that should at least get me in the right ballpark when I have concerns using a small hydraulic ram & a pressure gauge.
I had looked at a few hydraulic rams, like those in a porta-power unit & ran across the Strongway hydraulic 2-ton mini ram sold at Northern tools (& Amazon). It is a small unit with a cylinder face area of 0.95 square inches (diameter = 1.10"). It is a bit under 6" tall & 1.5" across. I bought one for about $23 & also bought a 0-1000 PSI gauge with 1/4" threads for about $10.
I removed the hydraulic quick connect fitting from the ram (it was tight!), extended the cylinder & added hydraulic fluid. I got the bubbles out & set the cylinder at about 1/2 extension (1.5" ?) then attached the gauge in place of the fitting. I made sure that the hydraulic fluid was level with the top of the hole when I attached the gauge to avoid adding air. The gauge was tightened until it was face up with the ram upright. A quick test in the vice showed the gauge respond to pressure & return to zero when the pressure was removed.
The gauge readings are a little above the actual weight (5%) but good enough for my purposes. It was simple to use with a jack stand as support. Lowering the hitch with the trailer's screw jack until the jack foot was unloaded (off the ground) I was able to see the empty tongue weights of the small dump trailer (400 x .95 = 380 lb) & the 18' Aluma car hauler (150 x .95 = 142.5 lb).
These are the pieces used (pics are from amazon):
   / Home brew tongue weight scale #2
Nice, not like the commercial ones are really any different.
I needed to get the 3038e back out to the acreage for mowing, so it was a good time to check the tongue weight of it on the aluma car hauler.
I put the tractor in the usual position on the trailer, lifted the rear feet & returned ramps to their storage postion. I then positioned the scale on a jack stand & lowered the jack until the support wheel was free of the ground.
With 480 showing, 0.95x480 = 456 lb. actual tongue weight
   / Home brew tongue weight scale #5
I love it! Nice job & Thanks for posting.:thumbsup:
2021 INTERNATIONAL LT625 (A52472)
2021 INTERNATIONAL...
JOHN DEERE  EURO BUCKET (A52472)
JOHN DEERE EURO...
2011 Kubota R520S Articulated Wheel Loader (A51691)
2011 Kubota R520S...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
16FT Flatbed Trailer (A51573)
16FT Flatbed...
