HOME BREW SNOWBLOWER MOUNT-DRIVE
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #1
vayidaho
SW Washington State
Kioti CK20H
Being somewhat disabled and not being able to turn my head around 180 degrees, I hated the thought of a new rear three point snowblower. I was not looking forward to weekly visits to my Chiropractor. I mounted a SPEECO Category 1 Quick Hitch in the bucket of the front loader, installed a hydraulic reservoir in front of the radiator, a hydraulic motor drive for the blower, and a PTO mounted hydraulic pump. I can blow snow looking forward and have height control using the loader controls. As it is only September 2010, I wont be able to test it until December. Requests for pictures should be sent to vayidaho@gmail.com. Will respond when tested and approved. Blowing snow in the panhandle of Idaho south of SandPoint, north of Spirit Lake. Tom
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #2
Would you post some pics on TBN showing your new rig?
We like pics and sounds like you have a clever design and approach.
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #3
Sounds like a winner!
I've thought of doing something similar but run the blower with a hydraulic motor connected to the power beyond.
M.D.
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #4
Sounds ingenious!
Love to see it.
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #6
Would be good to see some pictures if you can post them. I'm a bit leary receiving email with attachments to open from someone I really don't know.
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #7
Sounds like you also saved some $$ here.
A similar upgrade to mine more than doubled the cost over keeping it on the rear - about a $2000 option to mount it on the front.
Jon
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #8
Not gonna be powerful enough. I went through the steps and calculations on a 10HP chipper shredder and 7gpm wasn't enough flow. The snowblower is gonna need 15+HP from the same.
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #9
All i know is MI and E has done 7ft blowers off of the pto of the tractors and done well with it.
   / HOME BREW SNOWBLOWER MOUNT-DRIVE #10
Right, you're talking about a PTO pump with reservoir. I'm referring to MD talking about a hydraulic motor run from the tractor's pump. Different setups.
TEYME 2000 E0L0 GTE10 LOT IDENTIFIER 213 (A53084)
TEYME 2000 E0L0...
2024 KUHN SL124T LOT IDENTIFIER 60 (A53084)
2024 KUHN SL124T...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
ECHO PE-225 GAS WEED EATER (A51248)
ECHO PE-225 GAS...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
