Hole in fuel tank
   / Hole in fuel tank #1
Cougsfan
Veteran Member
Eastern Washington State
Ferguson TO35, Branson 4720CH
When I filled my 4720 CH with fuel today, I noticed that there is a pin hole sized leak in my plastic fuel tank. It is bad enough to cause a drip every few seconds. Fortunately it is up high on the goose neck, so it will only leak maybe a quart or so out if I fill it up to the brim. Not sure how I got it, but I have been mowing some REALLY heavy weeds on some land I have never been on before and have hit a few hidden items. Anyhow I definitely plan to fix it and am not really thinking I need to buy a new tank. Any suggestions on what might be the best way to patch it?
   / Hole in fuel tank #3
A critter chewed a hole in my woodsplitter's fuel tank (briggs). I tried a few different types of epoxy but it would always start leaking. After buying a new tank, I thought I would try to weld it with my soldering gun. I used the flat blade and used clean oil jug pieces for filler rod. It worked like a charm and years later, still have not installed the new tank.
   / Hole in fuel tank #4
I have used hot glue gun and the 1/2" glue sticks with good success on many poly things including fuel tanks.
Fusing with a soldering iron has also provided reasonable results.
   / Hole in fuel tank
I tried the hot glue gun approach. It was easy, and the glue can be removed if it doesn't work in the long run. It seems to have worked fine. I have been mowing tall weeds for several days now and it has stayed in place and seems to have stopped any leaking. If it fails I will try the more extreme measures. Thanks for the suggestions.
   / Hole in fuel tank #7
if its a pin hold, get a self tapping screw with rubber on it, like for a metal roof. shoot some RTV around it and good to go
That would be my approach, just make sure the silicone is fuel rated.........M
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
2016 Komatsu D61PX-24 Crawler Dozer (A51573)
2016 Komatsu...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
