Hoe mounting experience
   / Hoe mounting experience #1
petrops
Massachusetts / Vermont
Kubota L35
Hi all
I am looking at a few tractors with 9' hoes in the 40 hp range including Kubota, JD and Kioti. Also looking at a used NH 2120.
One big consideration is the ease of mounting and dismounting the hoes. Looks like JD and the Kubota TLB series (L48) have the mounting time trials nailed.
Can anyone tell me how tough the Kioti hoes are to get on and off. I am looking at the Rino 85 hoe for the Kioti.
   / Hoe mounting experience #2
I have no experience with the Rhino hoe. I have the Kioti KB2085, sub-frame mounted, and it's pretty straight forward. Back over the loader, hook up the hydraulics, make final position adjustments hydraulically, back on up. Insert two pins and the top link (lower links stay in place). Check connections and go to work. Ted DK-45
Quick Attach Pallet Forks (A47384)
Quick Attach...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
