Hobart Ironman 230
   / Hobart Ironman 230 #1
Mattc8832
West Virginia
John Deere 3032e,Snapper Pro SW20 and s200, Stihl Handhelds, BCS 830, Yamaha Rhino 700, 2 - Gravely 5260, New Holland LS 45 , 6,10 by 14 Trailer , Woods BH 6000 Towable Backhoe, Honda 21 Self Propelled, Exmark Commercial 21and shop full of tools
I bought a new Hobart Ironman 230 at Tractor Supply in Uniontown PA back in April 2010. I used it probably 4 times since then. I put a new roll of .035 wire on it and I noticed it was't pushing the wire out like it should kind of a bind. When I got it it had a 10lb spool on it and I put a 33 LB spool of .035 on it and thats when the trouble started. I put another 10 LB spool on and it works fine. Anyone ever had that issue before? It handles the 10lb spools fine but not the 33 LB spools. Anyone else had that issue?
   / Hobart Ironman 230 #2
Make sure the wire size is the same. Not common but have seen some cheaper wire that was oversize and/or labelled wrong. Also check that the wire feeds off the spool straight into the wire guide before the drive rolls. Usually unrolling from the bottom. Some feeders the spool hub can be adjusted up and down for different size spools.
   / Hobart Ironman 230 #3
Larger spools have more mass to get turning. Might need to tighten the drive rollers.
Smaller spools may need less friction on the spool hub, due to the smaller diameter giving less 'leverage' aganst the hub.
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2010 Toro ReelMaster Pull-Behind Hydraulic Reel Mower (A51691)
2010 Toro...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
