I placed a tentative order on a new 14k 24' (21' flat, 3' dove) with rear fold up ramps today. I got the equipment style with drive over ramps and the full 102" deck. this should weigh in around 3,500 lbs give or take. I think my f-150 is rated around 10,500 so I should have around 7,000 to haul with. I have added the add-a-leaf to the rear springs and also put on E rated tires and run them at 65psi (I know this doesn't change the truck GCVWR but it does change how it handles the load).
now to my question, should I get the weigh safe hitch to monitor tongue weight? I've never used longer than a 20' trailer and always just put the bucket to the front and strapped it down and never had an issue.
Also, on all of the campers you see they are set up with weight distribution hitches, why aren't equipment/ utility trailers, they are just as heavy if not heavier?
I went with the 14k trailer because in 4 years when its time for a new truck I will be going back to a 3/4 ton truck. I didn't realize how big a difference it is between the two.
