Hitch adapter from integral to three point
   / Hitch adapter from integral to three point #1
cmkh3
Kitsap County, Washington
John Deere 322
I have a JD 318 and it has the hydraulic tiller setup. I want to keep this as it works really good and get a second hitch weld a plate on top of it that it is 20" wide with flanges on the sides to take 3 point pints and a hinged type of rod to attach to the top link post .
Does anyone see anything I should watch out for or could be improved?
OH the reason for doing this is so that I can use most of the non powered standard three point stuff (OK small stuff) with my 318 as it is much much cheaper.
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Servis GYRO 84 Rotary Shredder (A50515)
Servis GYRO 84...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
Payment Terms (MUST READ) (A50774)
Payment Terms...
