Hinomoto Filters
   / Hinomoto Filters #1
buppy69
Platinum Member
Western NC
Hinomoto E2804, Hinomoto N239,
Does anyone know the filter numbers for a Hinomoto E264?
Eugene
   / Hinomoto Filters #2
Would it possibly use the same as an E23? I can get these for you.
   / Hinomoto Filters
Externally they look to be the same as the E232. I haven't taken them off to compare the threads. I am using the tractor a great deal and don't want it tied up if I can't locate the filters.
Eugene
   / Hinomoto Filters #4
Ok, on this E23 I have it has a Nissan brand oil filter with 2 sets of numbers, 1st set- 15208, 2nd set-H8911, It has a Mitsubishi fuel filter MD136466, and I found a Wix air filter 542076 works quite well.
   / Hinomoto Filters #5
I found some Purolater filter part numbers that might help.
Fuel: F55174
Air: A22011
Oil: L30042
However, I havn't tried these yet. Just bought a 2304, and will
see if these numbers work tmrw.
Does anyone know of a Hydraulic filter part number for the Hinomoto 2304?
   / Hinomoto Filters
I went to Massey Ferguson for the filters on my 2304 including the hydraulic filter. Ask for filters for a MF1030.
Eugene
   / Hinomoto Filters #7
Here is my data sheet...
E2004 and E2304 Parts Information
Air Filter: WIX 42276 OR Napa 2276
Fuel Filter: Napa 3262
Engine Oil Filter: Fram PH3593A, NAPA 1334 or 1348, Purolator PF1127
Engine Oil: Shell Rotella-T SAE 15W-40
Hydraulic Oil Filter: WIX 51174
Transmission Fluid: Hy-tran (JD-303 Equivalent)
Front Axle Fluid: SAE 90W
Antifreeze: 50% mix
Fan Belt: 15440; 15/32" wide by 44.0" long
Temperature Gauge sensor: same as 1990 Honda Accord Ex (luckily I bought that car when I needed the sensor and the resemblance peaked my curiosity)
   / Hinomoto Filters
Thanks for all the information but I keep getting numbers for 2304. What I need are numbers for a 264/2604.
Eugene
   / Hinomoto Filters #9
i have e264 engine oil filter is wix 51512 thanks tuttle
UNUSED RAYTREE RTSG30-30" STUMP GRINDER (A51248)
UNUSED RAYTREE...
Valvoline Brake Fluid (A53117)
Valvoline Brake...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
UNUSED CFG INDUSTRIAL XZ20R EXCAVATOR (A51247)
UNUSED CFG...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
KUBOTA L4600 TRACTOR (A51247)
KUBOTA L4600...
