Hinomoto E2340 Need 3 point help
   / Hinomoto E2340 Need 3 point help #1
SHIFTY
Connecticut
Just picked a couple of grey's,Got one straightened out ,On this 2340 I cant get the 3 point to raise or lower,It is up all of the way,I have tried the drop rate control,Their are only 2 servos,one for the side link and one to a spare set of remotes,It did have a tiller,I dont see anything that would electrically control the raise and lower,With the raise lever up it doesnt seem to have any effect with the hydralics,no straining,its just plain old stuck,The side link works fine,Is their some sort of disconnect lever hiding or a lock?Thanks in advance as well as thanks to EFC for the advice on the P19F which is now working like a champ
   / Hinomoto E2340 Need 3 point help #2
I had an incident where someone physically lifted the 3 point arms so high that it pulled the piston out of the cylinder under the cover, under the seat. I took the cover off and guided the piston back in and have had no problems since.
Did you mean 2304?
Eugene
   / Hinomoto E2340 Need 3 point help #3
Glad the P19F is working!! Call the shop 509-374-3398 if you get a chance and we can go through this problem. I have some questions to ask you.
Buck
   / Hinomoto E2340 Need 3 point help #4
Look under the seat, there is a turn knob that locks the 3pt hydraulics for road travel. Might check it - could be the problem.
MURRAY 21" GAS MULCH OR BAG PUSH MOWER (A51248)
MURRAY 21" GAS...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2016 Ford Explorer...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A51246)
2019 CATERPILLAR...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
