hinomoto e182-help please
   / hinomoto e182-help please #1
davisjames
I have a Hinomoto e-182. When you try to start it, the motor barely turns over, like a bad battery acts. I tried a new battery, but no change. Does anyone have any ideas or can anyone help. Thanks
   / hinomoto e182-help please #2
If you've checked your electrical leads and ground and everything looks good...Then it's the starter. Sounds very much like the armature shorting/dragging from excentric wear (either bushings or bearing). I would pull it off and have a re-builder test it and give you a cost for rebuilt or overhaul.
Good luck,
Mark
   / hinomoto e182-help please #3
Hi davisjames, welcome to TBN!!! Like Mark said, first check all of your connections, especially the ground and the + connection to the starter. If you have a bad ground, or a loose connection, it will cause the symptoms you are describing. The connections will also get VERY HOT!! I've been burned before fiddling around with a slow moving starter trying to figure out what was going on, so be careful. Good Luck, and let us know how you make out.
By the way, you might want to fill out your profile so people know what part of the world you are from /forums/images/graemlins/smile.gif Which makes me think, if you live in a very cold climate, that might be another reason the starter is turning slow. Does your tractor have a decompression lever?
Thanks for the reply. I'll check those leads, and if that doesn't help, I'll try the starter.
LOT IDENTIFIER 50 (A53084)
LOT IDENTIFIER 50...
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
LMC LOT IDENTIFIER 129 (A53084)
LMC LOT IDENTIFIER...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
