Hinomoto E14D radiator
   / Hinomoto E14D radiator #1
jambo
Hello everyone!
First Post Alert! :)
I've got an E14D that I've had for over 8 years, and love it! As I've read on this board, I'm not the only one who believes this little workhorse does more than it should. I use it with a Hino tiller, an ACTUAL 6' Bush Hog (ancient, but works - like me!), 12" auger, box blade, etc. I've had a leaky radiator for the past couple of years, and finally decided this year to get it fixed.
Went to a local radiator shop, where they tested it and said it was "rotten to the core" (is this where that saying came from? :) ), and it would cost me $300 to have a new core installed. $300!?!?! I know inflation is running crazy, but this little radiator weighs maybe 5 pounds (filled with fluid!), and thought that a bit strong, seeing as it's about 1/4 the price I paid for the tractor in the first place!!! :) So I go online to find what I could find.
First, I found a couple of used ones for a bit less (but not that much less, and they are USED after all), so I went searching for a new one online. I believe this tractor crosses to a MF205 (best I can glean from the net), and it looks identical to the MF205's I've seen pictures of. I found NEW radiators for this model for less than $200, but the measurements are WAY off!?! The ones listed for the MF205 are 17 1/2" H x 15 1/2" W (core size), but the radiator that came off my little trooper measures only 12" H x 12" W (again, core size). I've always thought this to be a bit small for a diesel tractor, but it doesn't look to be a force-fitted one.
Now I'm confused. I don't want to order a new MF205 radiator and not have it fit, nor even buy one of the used ones I sourced and have it to not be the right size, either! Can anyone tell me:
1) Does the Hinomoto E14D actually cross to the MF205? If not, which tractor does it cross to?
2) Does the "stock" radiator for the E14D actually measure 12" x 12" core size (a tad more, actually - about 1/4"), or do I have a gas model radiator or some other model's radiator?
3) Does anyone have a GREAT source for mail order radiator rebuilding they can give me?
TIA for any and all help in this matter. I have a E-series Workshop manual on the way, but I doubt it's going to include an IPL (but I can hope!)
Jambo
   / Hinomoto E14D radiator #2
All of my experiences with used radiators ended up at the radiator shop,, maybe it's just my luck but,,,,, As far as crossing over,, don't know, sorry. I'll give this a bump and maybe one of the parts guys will see it.
   / Hinomoto E14D radiator #3
Hi there,
if anyone can guide me to where i can get an E series (specifically an E14D) workshop manual, that would be great. :)
   / Hinomoto E14D radiator #5
$200 seems right i think one for my yanmar runs around $250ish dollars. It may have been small cause in Japan maybe its not as hot and they use it to till in water? Where here we bushhog more in hot sunny fields for longer periods? Was it running hot before leaking? If not i would not worry about the size. Also will the measurements of the MF look like they will fit, ie can you take a wider radiator without hitting the hood or somother bracket, smame with the hight?
2018 JOHN DEERE 5075GN LOT IDENTIFIER 91 (A53084)
2018 JOHN DEERE...
(APPROX 22) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 22) 2" X...
2004 TerraGator 8104 (A53472)
2004 TerraGator...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
