Hinomoto C174 do I need a new hydraulic pump?
   / Hinomoto C174 do I need a new hydraulic pump? #1
westsail434
Okefenokee Swamp
Hinomoto C174, Kubota 3901 backhoe,FEL, grapple, other attachments, John Deere 170, 3 Murray 12 hp rough cuts, Stihl chainsaws, Stihl trimmers,, Ryobi tiny tiller
Trying to get this thread in the right place. Sorry. I have noticed my lift pressure is slowly decreasing over time and getting weaker. I have changed the transmission fluid and spin on filter and it helped a bit but I feel it should be higher pressure, easier to raise implements. I looked through all my Simplicity and Allis Chalmers books and have some pics of secondary strainers but I'll be darned if I can find one on mine. Does anyone know if there IS a strainer other than the spin on filter on this unit? If so, where exactly might it be? If not I will have to get a new pump soon and can't find one for a C174. Any suggestions? Thanks again
   / Hinomoto C174 do I need a new hydraulic pump? #2
Why not start with buying a pressure gauge (less than $30) and part of a quick coupler to allow you to connect into your system and find out what pressure your system is putting out.
It may just need a relief valve adjusted.
A gauge of 0-3000 psi with a 2-1/2" face will work nicely.
Valley Instrument Grade A 4in. Stem Mount Glycerin Filled Gauge — 0-6000 PSI | Hydraulic Gauges| Northern Tool + Equipment
This gauge is a higher pressure than you need but is just to give you an idea of appearance.
Your local hydraulic shop will have a more appropriate pressure one.
Dave M7040
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
Orico 3000 Cook Top (A51573)
Orico 3000 Cook...
2016 Ford F550 Flat Bed (A52377)
2016 Ford F550...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
