hinomoto C-144
   / hinomoto C-144 #1
bdunegan
first let me say that I am a newbie, and glad I found this forum. now for my questions! just bought a hinomoto c-144 and am looking for some info on it. only has 522 hrs, and came with a continental belton 5 ft finish mower. am looking for possibly a manual that lists specs and capacities. does this compare with anything u.s. such as 1010 massey? am planning on using it to maintain 2 acre yard( good and level), and 1 1/2 acre pasture. what are the quirks, and what should i be aware of and watch for closely? seems to be a great little tractor, and everything works great, even 4x4. also what is the knob under the middle of seat for? possibly draft control for lift? am new, so anything is appreciated!
   / hinomoto C-144 #2
Hello!
I was told the C144 is the same as the MF 1010 by the person who sold it to me. He also provided me with a service manual for the MF 1010 & so far it seems to agree with anything I've worked on. I believe you can purchase manuals from Leonard Sheaffer (sheaftractor@grics.net, TractorByNet.com | John Deere, Kubota, New Holland, and more!) who posts on this board occasionally. If you have any specific questions about capacities, I don't mind looking them up.
I'm a little clueless about the knob you mention as well. From the manual, it appears the knob is used to adjust the lowering speed of the hydraulic lift arms. To increase lowering speed, turn knob counterclockwise; to decrease, clockwise; to lock, turn knob clockwise until stopped.
   / hinomoto C-144
Thanks for the response! until i get a manual, i need the capacities on engine oil and filter change, and hydraulic fluid. also where do you add hydraulic fluid at? know where to check, but where do i add. so far tractor seems tough built, and pretty simple engineered, just want to find out its limits. also is rear lift cat. 1, and what does the manual show for the lift capacity? sorry for the questions, but just need some quick answers before my manual arrives. Thanks again!!!
   / hinomoto C-144 #4
Engine Crankcase with Filter:
- Late tractors with two drain plugs - 3.0 litres (3.2 US quarts)
- Early tractors with one drain plug - 2.5 litres (2.64 US quarts)
Transmission: 17 litres (4.49 US gallons)
Front Axle (4WD only):
- Differential case - 1.5 litres (1.6 US quarts)
- Gear case (each) - .4 litres (.42 US quarts)
Those are the easy answers to find. I'll get back on the rest as I find them. I just added the hydraulic fluid on top of the case - I think there was a rubber plug but I'll have to check the next time I can get to them.
   / hinomoto C-144 #5
Easier to find than I thought...
For the standard tractor:
Hydraulic System
Pump Max Output: 14.2 litre/minute (3.75 gpm) @ 2,600 engine rpm
Pump Max Pressure: recommended operating max pressure 14.0 N/mm squared (2,030 psi)
Linkage: 3 point linkage, category I (looks like the capital letter "I" rather than a number "1")
Max Lift Capacity: 550 kg (1,213 lbs). Measured 610 mm (24") behind link ends (SAE J-283) with top link positioned in top hole and vertical lift rods attached in forward holes on lower links.
Relief Valve Pressure: 14.0 N/mm squared (2,030 psi)
   / hinomoto C-144 #6
For the hydro tractor (hydrostatic transmission?), the specs are the same except:
Pump Max Output: 13.5 litre/minute (3.56 gpm) @ 2,600 engine rpm
   / hinomoto C-144
Thanks again for your help! believe it or not manual has arrived, but after looking at it, i have but two more questions if you can help? my air filter is beyond help, and i cannot find any numbers on it anywhere. do you know what size and kind it takes by chance? also the manual shows the water temp sending unit mounted into the thermostat housing. i have looked my motor over upside down and backwards, and cannot find a sending unit anywhere. has a temp light, so must have a temp switch somewhere. was wanting to see if i could mount a temp guage on it without having something drilled and tapped! any help is once again enoramously appreciated! so far little tractor seems tough as nails!
   / hinomoto C-144 #8
Right now my tractors are on my parent's place (in a galaxy far, far away) and I don't visit except on weekends. I'll try to get down there soon to take a look at the air filter and look for a temperature sending unit location. I do recall that the air filter was a wire mesh cylinder that could be cleaned and reused. If memory serves me (and it usually doesn't), the filter was about 10" long with ~ 4" outside diameter & 2" inside diameter. I'll be sure to measure them when I next get an opportunity.
For what it's worth, I read a post from ~ 2000 (7 years ago) on another board that a guy used a Fram 530 air filter and expanded the hole on one end with a pipe expander to get it to fit. However, I've not found such an animal.
I did find what's described as an air filter for the MF 1010 at Air Filter but there's no picture to verify that it looks like the one I have.
Sorry I can't be much help there!
   / hinomoto C-144 #9
Hey, check this out from the MF 1010 group in this board (user name "lambs"):
"I have a 1010 2wd straight drive, and use the following filters. Had to do a bit of searching to figure them out, but they seem to work fine.
Oil: NAPA FIL1389, WIX 51389
Air: NAPA FIL6270, WIX 46270, Fram CAK530
Fuel: NAPA FIL3262, WIX 33262
Hydraulic: NAPA FIL1210, WIX 51210"
I checked the NAPA filter on the NAPA web site and it looks like the one I use. I hope this helps some!
2019 ExMark Lazer Z S-Series 72in Zero Turn Mower (A51691)
2019 ExMark Lazer...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
INOP/NON-RUNNING 2007 Peterbilt 378 Flatbed Mud Mixer Truck, VIN # 1XPFDT9X37D666626 (A51572)
INOP/NON-RUNNING...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
2020 JOHN DEERE 7R210 LOT NUMBER 50 (A53084)
2020 JOHN DEERE...
