Hinimoto E2004 won't start
   / Hinimoto E2004 won't start #1
hurricane10
Hinomoto E2004
About a month ago my tractor got hard to start it was very slow to get up to speed when starting. After started it would run ok. Then last week I had to hold the starter on until the engine got running, it seemed low on power and after about 5 minuets black smoke came out and it stop'ed and won't restart. I removed lines from injectors and very little fuel squirts when you run starter. Could it be the injector pump or the fuel injectors ? When I loosened the fuel supply line on Injector Pump lots of fuel flows and filter is ok. If its the injector pump where can you buy one. I live in Monticello, Fla .
   / Hinimoto E2004 won't start #2
Its a basic PFR type inj. pump.. any inj. pump shop can rebuild it..
I can do it also, probably at a substantial saving to you..
Just click on my screen name to the left for contact info.
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
12in Backhoe Bucket (A52128)
12in Backhoe...
7046 (A50322)
7046 (A50322)
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2011 Ford F150 (A50515)
2011 Ford F150...
