Hill descent
   / Hill descent #1
Catch95
Australia
Jinma 204
I put a post on the Safety Board about losing it on a hill in my Jinma 204. Basically I was going down the hill faster than the wheels were turning.
The question was raised re engaging the diff lock - can I do this while moving on a Jinma, and would the fact I had the PTO engaged on a slasher have made the situation worse?
Any thoughts would be much appreciated.
Mark
   / Hill descent #2
I quite often find a need to engage the diff lock while in motion. But I don't think that's the right solution to your downhill issue.
Jinmas currently sold (as new) in America have a two stage clutch. In situations like you describe, we need only kick in the clutch with one foot - while engaging both brakes with the other. The instant the clutch hits bottom, the PTO is fully disengaged. At that point, one finds a lower gear in which to descend said hills.
I'd be surprised if ANZUK Jinmas don't have the same two stage clutch.
//greg//
   / Hill descent #3
Jinma/2 stage clutch... I too believe that you will find most if not all Jinma's have a 2 stage clutch. On the 284 I just purchased I wanted it to be a 100% backhoe/loader tractor ( with SHUTTLE../to date the shuttle has been totally trouble free & I would never again order a tractor with out it...what a time & effort saver...) & would never do any 3 point work with that tractor. Thought if I ordered a single stage clutch I'd get longer life out of the clutch for the loader work/the single disk might be heavier/thicker? The dealer I deal with tried to order single stage clutch & couldn't get it...
2015 Chevrolet Impala Sedan (A51694)
2015 Chevrolet...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
