High sulfur fuel
   / High sulfur fuel #1
NIXON
Veteran Member
West Sunbury ,Pa.
L3130 hst
A local gas station sells "high sulfur " off road fuel . Is the "high sulfur " rating comparing it to the ULSD fuels now on the market,or,is it truly a high sulfur fuel ?
   / High sulfur fuel #2
Prior to fall 2006 most on-road diesel was "low sulfur" which I believe was 500pm. Now we have ULSD which is 15ppm I believe.
The older fuel, which may still be allowed for offroad use like farming, was I believe 5000ppm - 10 times more than what had been allowed on-road in the early 2000's. It probably won't cause a problem in a tractor that has no emissions system (most don't even if made today) but I would read your owner's manual to see if there are any fuel restrictions. I would guess that the "high sulfur" fuel is in fact at this very lax requirement, and not just at the 500ppm requirement for LSD. Is it significantly cheaper?
   / High sulfur fuel
To be honest, I never looked at the price :) I was wondering if it was compatible with My tractor first (L3130) . If so,then I'll look at the price .
   / High sulfur fuel #4
I believe the L3130 uses indirect injection, which is not very finicky about fuel. It should be compatible. However, unless it's a lot cheaper, I personally would use LSD or ULSD instead.
   / High sulfur fuel #5
Now, Off Road High Sulfur Red Dye Diesel #2 is 500ppm max.
This is the same as On Road #2 Diesel was before the switch to ULSD.
Of course, ULSD is 15ppm sulfur max.
Any contaminated and/or adulterated ULSD is simply sold as Off Road Diesel #2.
2005 Sterling Acterra Tender Truck (A55301)
2005 Sterling...
2014 JOHN DEERE 250D SERIES II OFF ROAD DUMP TRUCK (A52705)
2014 JOHN DEERE...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
