high speeds on fan not working.
   / high speeds on fan not working. #1
gottabediesel
The roof of my 5030 got damaged and mice got into the roof. Ive taken off the top cleaned everything out and looked at the wiring. The heater fan works only on low, not the top 2 speeds. I'm told there might be a resistor that can be replaced to rep[air it but im not sure where to start. Any suggestions besides - fix the roof next time Moron??
   / high speeds on fan not working. #2
Typical sign of a bad blower motor resistor is fan only works on high which is full 12 volts and bypasses resistor which steps voltage down for slower speeds.
   / high speeds on fan not working. #3
It looks like there is a resistor for the blower motor if it is needed and it can be found in the roof.
You'll have to verify the PN is correct.
RESISTOR, AIR CO, Part # T1065-72180
Part Number: T1065-72180
Vendor: Kubota
Messick's Price: $52.22
Stock Quantity: 0
Weight: 0.20 lbs
Days to Order: 5-7 business days
See item 80 in the attachment.
Good luck!
  • Blower Resistor.pdf
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A52748)
GALAXY - SET OF...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
