High range squeel
   / High range squeel #1
pk1mk1
What would cause a my 3015 to squeel when accelerating in high range--either forward or backward?
   / High range squeel #2
I had a dust boot come loose on the drive shaft on my Kubota B3030. It sounded awfull. Sounded like a bearing was shot. Dealer retightened the boot and put some silicon around the boot and no more problem's. I hope yours could be this simple.
   / High range squeel #4
Is it HST? I've never had one but I've heard people complain that they squeel. If it has caused concern though I'm guessing it is a bad squeel and not related to HST.
This is your new Mahindra? You have your dealer to fall back on, which is good.
   / High range squeel #5
Memory is a bit foggy on this,but back 3 or so years ago I posted about a problem with the Deere 10 series squeeling. Contacted a friend at JD,turned out being a valve in the tranny as the culprit. Might be able to find it in the archives if you look.
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
2017 Ram 1500 Crew Cab Pickup Truck (A51692)
2017 Ram 1500 Crew...
MOBILE OFFICE CONTAINER (A53843)
MOBILE OFFICE...
