High Low Lever Limit Switch
   / High Low Lever Limit Switch #1
AuburnNW24
I bought a TC24DA with last summer and love it. The only trouble I am having is that the High Range - Low Range lever doesn't always make the limit switch when in Neutral. So when I set the parking brake, place the tractor in neutral and hop off the seat the tractor shuts off. I am convinced the safety features are there for my protection so I don't want to bypass them. Has any one else has this trouble? How did you fix it? If I wiggle the lever to the right position it will not shut off, but this is a pain every time I want to open a gate or hop off the tractor. I am also assuming that it is better to let the diesel run rather than restarting it. Thanks for the help. Looking forward to Spring!
   / High Low Lever Limit Switch #2
I have the same problem with my 33 although very rarely. If it were to get any worse I would just follow the linkage looking for a switch. Make sure it's properly aligned for full contact with whatever engages it.
I alwyas leave the tractor running when I'll be off for a short period of time, or letting the engine cool down before shut down.
Did you buy the tractor new last summer? If so, have it done under warranty.
Welcome to the board and if I understand your screen name, your just a bit south of me.
   / High Low Lever Limit Switch #3
The switch is external to the range shift linkage. It can easily be adjusted to work properly i believe a 7mm wrench is all that is needed.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2008 D&P WELDING  18FT 2000 GAL FUEL TRAILER (A52472)
2008 D&P WELDING...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
2016 JOHN DEERE 135G (A52472)
2016 JOHN DEERE...
