High Efficiency Residential Boilers Mfg??
   / High Efficiency Residential Boilers Mfg?? #1
NY_Yankees_Fan
Veteran Member
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
Does anyone know of any high efficiency boilers? I found this company link and it looks like this is state of the art boiler, claims 30-50% reduction in fuel cost. My 17 year old natural gas boiler is at best 50% efficient and I think maybe too small for our house, it seems to run all the time, and out gas bills seem to be going up, last one was $550. We have a tankless hot water 80 gallon and 3 zone hydronic system. With the tankless heater, installed in 1999, the boiler runs year round. House is 3,000 sq. ft., 17 yrs old, R11 in the walls and R 30 in the attic. Boiler is rated at 95,000 BTU input. I expect to be in the house for another 10-15 years. Nothing wrong with the existing boiler. Am I nuts to replace, or do you think the savings in fuel would payback in a few years? Any idea on how to size the BTU of the unit I would need? and how I would calculate potential fuel savings?
   / High Efficiency Residential Boilers Mfg?? #2
Tom,
As a Red Sox fan, I'm happy to give advice (even if you guys did steal A-Rod)! You might get one of the software packages that does all the calculations on heat loss, etc. Although there might be rules of thumb, I think all the variables you mentioned are well modeled by these packages.
I believe a friend of mine just put in one of these high-efficiency European LP boilers, might even be the MZ you indicated. He's really pleased with its performance. I'm building a new house and am considering it as well.
It has dual outputs - one at higher temps for hot water, and another at lower temps for hydronic heating coils.
   / High Efficiency Residential Boilers Mfg?? #3
Tom I have always preferred Carrier/Bryant equipment. Have a local heating firm do a heat loss on the home so that you don't end up with a boiler that is too small or too large. Higher efficiencies will save you a bundle over the life of the equipment. Especially if you are talking high efficiency and comparing it to your old 50% eff. boiler. Most reliable heating dealers will also have a software program that will chart the savings for you based on the efficiency that you decide to go with on the new boiler. Keep warm. /forums/images/graemlins/grin.gif
   / High Efficiency Residential Boilers Mfg?? #4
Tom , Take a look at www.takagi-usa.com .
I have a tk-1 in my house and it's been flawless ( 3+ yrs . )
I only use it for domestic water heating , not for heating the house . But it has no trouble supplying water for two showers at a time . A sort of wierd , but useful feature is that it has a remotely mount temp control box( optional ) . You can vary the water temp from 100- 168 Degrees . The remote does have one downside , if you lose power it shuts off the boiler ,and you have to manual turn the remote back on ( at the remote ) . As your in the market , it might be worth looking at . John
   / High Efficiency Residential Boilers Mfg?? #6
Are you looking for a boiler for the hydronic heating only or the domestic water heating or both? What is the tankless 80 gallon in reference too? I used a tankless heater for domestic water heating for a number of years and was not impressed. I am currently looking into a high efficiency boiler for our radiant floor heating system we are considering installing in our too be built new home. If yours is at 60% or less effciency, I would suggest you start looking. A gurantee is that natural gas prices will not be going down especially at the rate the new natural gas fired electrical generating plants are being built. The demand for natural gas is huge and getting bigger all the time. The "highway" to carry it is adding to the problem.
Rat
I am looking for a boiler to supply hydronic hot water and supply the hot water tank.
The 80 gallon tank is located next to the boiler and is supplied hot water from the boiler via a zone valve to a coil in the tank.
We had to go to a 80 gallon tank because of the 2 person jet soaking tub in our bathroom that we use about 2-3 times a year. /forums/images/graemlins/tongue.gif
So far I have found the following:
link
This web site actually sells everything you need including the boiler. link $4K just for the boiler. Figure another $1K to install, $5K total, my annual heating bill is about $2K, at 30% savings, $600 a year, 8 year payback, got me thinking and the CFO. So we are going to add more insulation in the attic and bring it up to R44 from R30, reprogrammed the thermostats to keep the house at 67F at night when sleeping, down from 69F, and see what that does. Going to borrow an IR camera from work and see where my heating loss is and try to fix that. If natural gas prices keep going up, I will end up switching anyway, but at least the CFO will know we tried everything. /forums/images/graemlins/grin.gif
   / High Efficiency Residential Boilers Mfg?? #9
NY Yankees Fan,
I think you are on the right track with insulating the house. I
was reading through Richard Truthoy(sp)'s, the HVAC guy on
This Old House trying to find info on what you and I are doing.
He said for an existing house have an energy audit performed.
But since that requires the use of a blower door I'm not sure I
would be doing this in the winter.
He did say the cheapest think to do would be caulk up the
house and had insulation. Then look at the HVAC systems.
Modern equipment is more efficient the longer it runs. The
cost is at start up. I'm pretty sure my Heat Pump is to big for
my house so it starts frequently which is the expensive thing
to do. The energy/dollar cost is a sharp curve up at startup
time and then drops drastically there after.
Rats comment about gas being more expensive is almost
certainly correct. There was a story today in the Wall Street
Journal talking about the demand for gas and the corresponding
spkie in prices. The increased demand is due to the
government pushing gas since it burns clean. There also is
very little domestic searching going on for more supplies,
supposedly due to environmental regs, and the domestic fields
are getting old. Because of this chemical and plastic
production(jobs) is going to flow overseas. /forums/images/graemlins/frown.gif
Try http://www.radiantec.com. They have lots of
info on radient heating systems. I don't think this is what you
are really looking for but they have some rule of thumb
formulas to calculate how many BTUs you need to heat the
house. The also have some boilers that might be interesting.
For BTUs, my new house which has R20-25 walls, R35-40
ceilings, and 2500 sq. ft. requires about 40,000 BTU to heat
But I'm just a wee bit farther south than you! /forums/images/graemlins/grin.gif
Just had a thought? Does the maker of your current boiler
have a website? Maybe they have info on your particular
model requarding sizing?
Later,
Dan McCarty
   / High Efficiency Residential Boilers Mfg?? #10
I have a Buderos system with integrated indirect hot water heater. I am very very happy and they told me it is state of the art. It is manufactured in Germany which used to make me happier than it does now (pre-gulf war II).
http://www.buderus.net/
I love mine!
2015 PETERBILT 367 (A53843)
2015 PETERBILT 367...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2018 DRAGON 130BBL VACUUM TRAILER (A53843)
2018 DRAGON 130BBL...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2021 Allmand Bros Maxi-Lite II S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
