Oil & Fuel High Cetane Fuel
   / High Cetane Fuel #1
race_engr
At the advice of a diesel mechanic friend, I switched from 40 cetane farm fuel to premium 47 cetane road fuel. Since I don't use more than 20 gal./year, the cost was not an issue.
I have a YM180D and have been very pleased with its performance but........with the 47 fuel, it runs like a new tractor!!! Less smoke, easier starting, and less RPM loss with rotary cutter in use on grades.
If you haven't tried premium fuel, do so. You won't regret it.
--BB
   / High Cetane Fuel #2
I noticed a difference between what we call "off road diesel" and the diesel sold for trucks , Brian
   / High Cetane Fuel #3
Did it run better or worse on the truck diesel? I've been buying off road diesel because it's so cheap, but at 1/2 gallon an hour I guess the cost really doesn't matter much.
   / High Cetane Fuel #4
I have started to use a deisel fuel additive . Power Service Cetane Boost . It increases the cetane level and also adds more lubrication to the fuel pump . In my opinion , it does seem to run cleaner (exhaust smoke) . It was fairly inexpensive and if you mix it properly it only requires 2 ounces per 5 gallons of fuel . Should last all summer !! It is suppose to help keep injectors clean too .
What do all the rest of you think about fuel additives ??
   / High Cetane Fuel #5
Couple posts at the old yahoo site on fuel additives - concenses was that many people use them - it's cheap and simple. Many are anti-gel as well.
   / High Cetane Fuel #6
should we have alot of exhust smoke.. the only time I get alot of smoke is when I really hit the throttle hard and fast then its black with just a little grey. I know what use to take me 3gal of gas now takes less than gal of deisel to mow..
   / High Cetane Fuel #7
Same here . The deisel uses much less fuel than the old Kolher powered lawn tractor . I believe a little exhaust smoke is normal with black smoke when under a heavy load . For the most part mine runs very clean exhaust .Don't think I could ever buy an other gasoline powered tractor again !!!
   / High Cetane Fuel #8
Mine burns clean unless I load it past it's ability....then it burns dense black and loses RPM 'till I reduce the load to something reasonable. Then within a few seconds it is back to clean burn again.
I run automotive type premium diesel. I've tried most all the ag and truck fuel blends in the last 25 years and prefer the premium diesel. I've only used a diesel additive once and that was for a suspected sooted injector. I think it might have helped.....then again it may have simply been the new premium diesel fuel and time.
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
