Oil & Fuel HI. My BX2370 leaks from the hydraulic drain port.
   / HI. My BX2370 leaks from the hydraulic drain port. #1
Clyde in TS
Tumbling Shoals
Kubota BX 2370
This is my first time owning and maintaining a tractor. It started leaking from the the hydraulic fluid drain port. Does the sealing shim need to be changed with each UTD fluid replacement? I saw no such requirement listed in the manual. What els could cause the leak? I did not leave it loose or overtighten the drain plug when I reinstalled it.
   / HI. My BX2370 leaks from the hydraulic drain port. #2
Depending on the style of seal yes it might need to replaced with every oil change.
   / HI. My BX2370 leaks from the hydraulic drain port. #3
If it is a copper disk I would heat it with a torch red hot and let it cool. That will aneal it, softer. I would put a vacuum on the fill hole to remove plug so you keep the oil in the machine and put together with the anealed washer
   / HI. My BX2370 leaks from the hydraulic drain port. #4
Ive seen these with simply a bit of gunk under washer preventing tight seal. Ones that didnt bother running a rag around hole before sealing.
More info coming soon! (A48081)
More info coming...
Deluxe Hitch Plate (A49339)
Deluxe Hitch Plate...
2015 Ford Escape AWD SUV (A46684)
2015 Ford Escape...
1/2" Universal Quick Attach Plate (A47371)
1/2" Universal...
Massey Ferguson 275 2WD Tractor (A49251)
Massey Ferguson...
MTL Extreme Grapple Rake Tractor Attachment (A46683)
MTL Extreme...
