HF Circular saw sharpener
   / HF Circular saw sharpener #1
waggy1
Baltimore, Ohio
Kubota L48
Has anyone used a HF circular daw sharpener on a carbide blade and what were the results. I would like to be able to sharpen my carbide blades myself and save some money. Thanks!!!
   / HF Circular saw sharpener #2
I have not used one, but i looked at it in the store. At first glance it seemed like a good money saver to me, however I didnt believe it would be worth the money based on my experience on buying the chainsaw sharpener. On the chainsaw sharpener , it seemed to have wiggle room when moving the motor up and down and there was no way to adjust it to make it tight. i checked for play on the circular carbide sharpener and found that the arm lock and sliding movement to move blade to be sharpened also had too much wiggle room for my taste. looked like a waste of money. Also when i tried to move the blade to pretend to move to next teeth to sharpen, i was suprised on how easy it would be to cut myself since there was too much friction and no gaurds to protect my fingers. IMHO - its not worth it. If carbide is supposed to be very flat and cant have angles on it to cut, what are the chances HF will remove those perfect flat surfaces ? Its cheaper just to buy new blades then it is to buy this tool.
   / HF Circular saw sharpener #3
Radioman,
I have not had any issues with the Chainsaw sharpener for the past year or so, about 10 cords of wood cut on about 5 chains all sharpened with it the HF tool. I mounted mine on a 2x4 that then put in the vise and it all seems to work out right.
I have no experince with the circular saw machine, but was intersted checking it out.
I also have the chainsaw sharpener and it works fine. I still am unsure about the circular saw sharpener. That is what I need to know about. Thanks for your replies.
23018 (A53424)
23018 (A53424)
TRUCKING INFO (A50775)
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
1995 HESSE CORPORATION BEVERAGE TRAILER (A53843)
1995 HESSE...
