HF Chop saw
   / HF Chop saw #2
It's also cheaper than renting an attachment to use on a borrowed Bobcat SSL to jack hammer an old foundation to break it up. I wonder if I could use something like that to cut up an old garage floor into small enough pieces I could pile them up with my little dozer and load them into my dump truck with my FEL on the Deere. Any thoughts?
   / HF Chop saw #3
You're gonna be cutting a long time with any saw like that, not to mention blades. Best way to remove an old slab is to slightly lift an edge then use a sledge hammer, you'd be surprised how easy concrete breaks once its off the ground.
   / HF Chop saw
I was thinking what Syncro said, before I rented anything, I would try getting under an edge and lifting, then dropping with a rock or something underneath.
I have to cut about 8' for this project, any longer and I would be looking at a different way of doing it.
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
50 CAT 5 TOOTH EXCAVATOR BUCKET (A50854)
50 CAT 5 TOOTH...
71050 (A49346)
71050 (A49346)
1996 FRUEHAUF 48X96 T/A FLATBED (A50854)
1996 FRUEHAUF...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
