hey Spencer
   / hey Spencer #1
OrangeFloyd
Pac N\'West
Kubota B7510
I see from your extended drill bit photo that you have a little Miller wire feed machine. Is it 120vac? How do you like it? Do you do any aluminum?
I'm thinking about getting a little wire feed welder. Looking at the Clarke 135 models right now.
thanks -OF
   / hey Spencer #2
Hey, I'm not Spencer! I do have a Miller 130 120V mig welder though. It is great for sheet metal and light welding projects. The only problem I have is that I think I have out grown it. Check and see what the max. capability is of the unit you want, if it will handle what you plan on doing but is close to it's max., buy the next size up unit. My welder has four settings, most of my welding is done in the top two settings. The welder has a thermo protection device built in and if I have alot of continuous welding to do, I can go for about 15 minutes and the thermo device kicks out, (it works like an auto-resetting circuit breaker) and welding stops but the fan continues to run. I can resume welding after about 10-15 minutes only to have it happen again. For intermittant or light welding I have never had a problem with it and it works very well. Even doing my heaviest welding with it, it has never failed me. I've had it 8 years and would recommend the same unit to anyone else. Like I said, I think the problem is I have out grown it but I will keep it for lighter work and for the portability of it.
   / hey Spencer #3
OrangeFloyd, actually that little Miller box is a plasma cutter not a wire feed welder. It is a Spectrum Cutmate 375, I described it in a previous thread of mine.
You can view that description here:
My Personnel Lift Project
Here is a link to a picture in that previous post that shows a close-up of the plasma cutter.
   / hey Spencer
tks spencer
i knew it was a plasma cutter
ok maybe i didn't
things have changed since i was doing it on a daily basis
great pics
don't forget to check the voltage!
-OF
2022 Wacker Neuson SM100 Mini Skid Steer (A52748)
2022 Wacker Neuson...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
John Deere 300 Tractor W/Loader (RUNS) (A50774)
John Deere 300...
