Hey guys got my self into a pickle here
   / Hey guys got my self into a pickle here #1
Knifer
Bronze Member
Winter Haven
Massey,JD 2010, International W6. '42 case
I have a ford 2000 1964
serial on the tractor says it's a 144 cid diesel
I spun a rod bearing and destroyed the crankshaft. I decide to rebuild and the motor and replace the crank since no one could turn it. Anyway I order everything for the 144 and nothing is right rings too small crank to stroked
So i came to the conclusion the motor has been changed over the years.
I have been trying to figure it out.
it's 4 cyl diesel
Here is the info I have casting number on the block d2nl 6015L
there is also a number stamped by the timing cover d3-jl-607-L
the bore size is 4 1/8 inches
the piston have 2 compression rings and 1 oil ring, the set I ordered had 3/1
I have already dropped a crap load in the parts hoping I can return them.
I really like the tractor and hope I don't have to junk it.
   / Hey guys got my self into a pickle here #3
It may be a 172 or 192 cu in. I found these guys that sell new, rebuilt and used engines. Yours is supposed to have the 144 but as you found out it doesn't. Maybe they can help you decipher the castings. They also have parts. Check the casting number on your crank and compare to the crank casting numbers they have on their site.
Ford Tractor Engines
According to this site your d2nl casting indicates it may be a 1972 motor. Not sure on that because it's about industrial ford engines.
How to Identify a Ford Industrial Engine | eHow
This third site also confirms your motor is a 1972 tractor engine.
D is decade of 1970's (if it was C2 that would be 1962)
2 is year 1972
N is tractor
L is industrial engine
Ford Part Numbers, Casting Numbers, and Date Codes
yea it seems like the bore would tell me the difference in the two sizes
thanks for replying got another lead to follow
2013 VOLVO EC220DL EXCAVATOR (A52472)
2013 VOLVO EC220DL...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52748)
2022 Down2Earth...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
